My OCC2 gives a blank screen when powered on. The composite video output is OK. There is a faint glow in the end of the tube. The voltage readings from the PSU is OK. After some checking I suspect the horizontal output transistor to be defect (Q103, under the heat sink). Its markings is 88245 1070. I have tried to google these numbers to find a replacement, without luck. Does someone know if there is a similar transistor I can use? I also wonder what might have caused the HOT to "die" and what other components that this failure might have affected. Any suggestions will be greatly appreciated.
