krebizfan
there's no real damage to the board, only the soldered battery that i took out (to prevent leakage of it), but the board seem to be fine.
Edit: the HDD in it is a Quantum Trailblazer tr84a011, 850mb. Here's a photo of my screen at the BIOS hard disk config.
Edit2: i noticed that everytime it reboot (after "saving changes"), it still give me an "ACFG" error, and when i go back in the BIOS, the HDD configuration is reset to 0/none. So does that mean that everytime it reboot, it forget the hard disk configuration??
Have you replaced the battery? Without a working battery, the configuration changes will not be saved. There should be an external battery connector on the motherboard. The documentation I linked to before claims that a 3V lithium is needed so you can make one out of a CR2032 button cell and holder. Holders that had the correct wires to go to the motherboard pins used to be common.
