maelstrm
Has anyone had any luck with a packet driver for the Xircom RE-100 PCMCIA card?
I've been trying to get it to work under DOS with MTCP. But each time, DHCP times out and says to check the cabling and packet driver settings. I have Card Services running (C:\CARDSOFT), and it is detected by Card Services. But I get no link lights.
I'm running PC DOS 6.3 on a Toshiba 4005CDT. I have also tried with MS-DOS 6.22 but with no luck.
In my autoexec.bat, I have:
And my MTCP.CFG file has
If this is changed, MTCP's DHCP won't even run, and it will error out with "could not set up packet driver."
At startup, I get (from Card Services) "The driver has been successfully registered with Card Services".
I tested the card with this same machine using Windows 98, and the card itself works fine.
CBEPD.COM SINT=6A
packetint 0x6A
