I don't get those beeps for the 16-bit Cirrus card I've been using.Are your motherboard switches set correctly for EGA/VGA? On my 1986 XT, VGA will work fine without the switches set correctly, but you get the beeps for no video, even though the ROM gets initialized.
Although I am getting two long beeps before the video lights up and the POST RAM test starts.
https://minuszerodegrees.net/5160/misc/5160_motherboard_switch_settings.htm
Assumption: Your IBM XT (IBM 5160) motherboard's BIOS ROM's were no swapped out for third-party ones.Yes, I do have POST cards, but as far as I know, XT 5160 doesn't issue those checkpoints.
The BIOS author can do pretty much what they want to.Do VGA BIOSes do that?
According to my reading of the BIOS source listings for the IBM 5160 motherboard, that BIOS does not issue two long beeps. If I had seen '2 long beeps' in the source code, I would have listed 'two long beeps' at [here].
For example, we know that the BIOS on an IBM EGA card will issue {1 long beep then 3 short beeps} if the card's BIOS discovers some cases of faulty video RAM.
Rhetorical: Could it be that the two long beeps is your VGA card informing you that it discovered a problem during its self-test? Does the card do that when it is in a different computer?
But... with that VGA card in the system the XT-CF-Lite is flaky. Sometimes doesn't display the correct ID string for the CF card.
With other VGA cards, I've never seen that symptom before.
Background: At the high level, the XT-CF-Lite hardware looks like [here].What address is the XT-IDE set for? There are some VGA cards that might conflict with C800, according to this: https://minuszerodegrees.net/xtide/XT-IDE - Basics.htm
I think Jafir mentioned that in case your XT-CF-Lite had been configured to start its ROM at C8000.The VGA ROM is at C0000 (and doesn't extend beyond and affect the MFM disk controller at C8000 when I checked it on the XT 5160).
340 is uncommon for an XT-IDE/XT-CF card. The vast majority of those cards default to 300. Perhaps try 300.XT-CF-Lite is set for D0000 and 340h.
