PDP-8/e case lid latch
thunter0512
Perth in Western Australia
I have nicely straightened the warped lid of my new PDP-8/e so it fits the case with all gaps parallel and neat.
It looks like originally the lid was fastened to the power supply side via two black plastic latches attached to the front and back of the 8/e power supply.
Below is a photo of what is left of the front latch:
The latch shows the manufacturer as "Southco, Lester, PA.". The company still exists (https://southco.com/) and makes all kind of gadgets. They even have an Australian distribution center.
Could somebody with an intact version of this latch please make a photo of it and its counterpart on the lid?
Alternatively does somebody know the type of latch (or whatever the proper name is) and if it is still available?
Thanks
Tom
I am interested in this as well. I did not know there was a latching mechanism involved. My lid has two of those little black plastic squares and the power supply also has those. It looked to me like the lid ones rest on the power supply ones. But a latch of some kind would make sense. The detail on the drawings is not good enough to tell what they were doing.
this, I think. standard style
nope.. those have two screw holes, the DEC one only has one
I have three chassis and all the latches are broken/removed
What normally happened is the hinge part would crack apart and you'd loose the big rectangular piece that slid down
My Power supply side is missing the latches (and the power supply guard to keep your fingers out of there). Here's what I have for the cover bits. They sort of hook over the power supply, so that you have to spring the thing a bit to get it off. They are riveted bits of something that feels like metal but looks like plastic. I had naively assumed that was how it should be.
Vince
Thanks Al.
These are suitable for the Kaypro II and Osborne 1, but not for the PDP-8/e.
The latch for the 8/e is about 1/2 the width of those and much shorter.
I looked through a large number of images found by google but nothing seems to be close.
It appears that not many of these latches survived intact.
The "Illustrated Parts Breakdown" document for the PDP-8/e shows the latch on page 3 as items 30, 31 and 32S (see detail A on top left of page 3).
Page 5/6 lists these as:
30: Spacer Latch
31: Latch, Draw Catch Fastener
32: Screw, Flt Hd No. 6-32 x 1/2
The document can be found at:
http://www.bitsavers.org/pdf/dec/pdp8/pdp8e/PDP-8E_IPB_Feb74.pdf
It looks like Southco no longer makes these latches - or at least I couldn't find it on their website.
I got Southco to send LSSM a few samples of the ones Al mentioned above. They are not the correct ones for the 8/e chassis. They are nice, though, and it looks like they probably will fit Kapros. One of our guys is going to give that a shot this weekend. If they work, that'll solve a different problem, so still a win. :)
-Dave
Ahh, you've tried them? Excellent. We will go ahead and order some for our Kaypros and Osbornes then. We have something like ten of each, all with broken latches. Thanks!
-Dave
-Dave
Make sure you get the "Standard Style". I got mine from RS Components in Australia about 2 years ago, but they still have plenty in stock (350 as of now):
The Southco part number is: 07-10-201-12
