Angry Person
- Joined
- Aug 20, 2014
- Messages
- 20
Hi all!
I have recently bought a Pentium Overdrive off Ebay... an 83mhz original for socket 2/3. Having wanted one for a long time I couldn't pass this up. To be honest I've always been interested in the Overdrive 63/83 pentiums, due partly to the features found within the chip.
But anyway, I am having issues with this particular chip on my (only ) socket 3 motherboard - an unknown OPTI based motherboard (with a 237 pin ZIF socket, PCI, ISA, VLB and 256k L2) from the early to mid-nineties. The board has been working with a 486 DX2/66 for a while now, so I figured that the Overdrive would work OK considering it works at a 33mhz bus speed and is able to operate on 5v sockets, like the 486 Overdrives. Yet, when I start the board with the Pentium inside the CPU fan spins up with the PCI IDE card (Promise Ultra33) initializing, but there is NO display at all and NO audible post message from the speaker. When I reinsert the 486... all returns back to normal. I know this could be a simple jumper for the overdrives but I am unsure. What is more annoying is that the CPU jumpers are not silk screened onto the motherboard either!
I have tried removing the RAM and all the I/O cards from the motherboard and no dice; there is still NO beep from the motherboard speaker, which there is if the 486 is inserted. Having no prior experience with 1st gen Pentium Overdrives... I am asking for help in order to understand what the issue is and whether it can be solved or not.
Thanks for reading!
Thanks for reading!
