| VCF East | Apr 17 - 19, 2026, | InfoAge, Wall, NJ |
| VCF Latam | Apr 24 - 26, 2026, | Bahía Blanca, Argentina |
| VCF Pac. NW | May 02 - 03, 2026, | Tukwila, WA |
| VCF Southwest | May 29 - 31, 2026, | Westin Dallas Fort Worth Airport |
| VCF SoCal | See you in 2027, | Southern CA |
I must say floppy support is generally excellent - everything is only really for pure DOS mode.I just received my PicoMEM today and plan to put it into one of my Book8088 systems. I'll start playing with UMBs and floppy support first, and report back if I have any notable observations.
Hi,My PicoMem board will be here tomorrow! Eager to try it out in my IBM Model 30 with the NEC V30 8mhz.
Got the Adlib add on also.
Things of interest for me.
1) WIFI Internet vs hared wired car installed.
2) Adlib quality
3) EMS support vs LoTech 2mb card installed.
I don't see this on the list of tested devices, but hoping this works out well!
Any concerns / settings /ect I should know / worry about?
I use it on the Book as well, so no conflict with existing internal hardware.Hi @FreddyV - having issues getting the USB OTG mouse support to work (I have a 3 port OTG hub) - I have a book8088 v2, and wondered if the serial / parallel irq's are causing an issue?
IRQ > 7 is not supported for the moment, I added the possibility for >7 for my tests.Got some time tonight to play with the PicoMem board.
1) Small visual bug. Set IRQ to 10 for WIFI. Then set it to say.... 9. It will now show 90 on the screen.
2) Set the EMS Port to 2A8. Now the PMEMM.exe detected the EMS and 4mb of EMS memory showed up.
3) One time, with PMMOUSE.exe ... I got Divide overflow error? I still have yet to get my PS2 mouse to work if PicoMem is installed. The IBM Model 30 has two PS/2 ports. Uninstall board, boot off floppy or old drive, and mouse works.
4) I switched to PM2000.com which works it seems.
5) Even with using PM2000.com, my HTTPServ goes silent after a while. If I keep hitting up the web server it works. But if i leave it idle for a few minutes. No longer works.
1) Ok, Really sorry for that, the only thing I can think about is an issue with DMA I am already working to correct it.Got my PicoMem v1.11 board today!
IBM Model 30 - 8086 - 640k - NEC V30 8mhz CPU with math coprocessor.
Installed, along with the Trident 1mb VGA card and CH375 card with FreddyV drivers.
Card set to IRQ 3
1) Not 100% sure what I did, but my main disk drive got corrupted right away. I should have removed it first? Nothing important lost.
2) Adlib works! Rail Road Tycoon sounded great!
3) Made 256mb HDD Image - Works great so far. DOS 6.22 Installed.
4) WIFI works great so far. Using the NE2000 from PicoMem Github. Also mTCP for all internet traffic support.
5) EMS - Using PicoMem EMS driver from GitHub - nothing found?
6) EMS - Using LoTech EMS driver - 2mb found and works ( I have a lotech 2mb card I removed so had been using this before )
7) Every time I turn system off, EMS settings are cleared out, and I have to re-enable it?
8) Every time I turn system off, USB Host ( i set to off) is back to ON again?
9) Not 100% sure related yet to #8?... CTMouse.exe is what i've used in past. It seems to detect my PS2 mouse. But mouse is virtually unresponsive. Stuck in bottom corner.
10) If forget to put in microSD card, and try to create an HDD image. It doesn't seem to have a fail message? But if you do have microSD in but didn't make the HDD folder, it knows folder doesn't exist and complains.
- Did not test floppy image support
11) I like the PicoMem BIOS like setup. Would like to see maybe A save option? So can exit without saving changes?
Other than some qwirks maybe, this is really cool. Can remove hard drive / rj45 network card / lotech card ... and replace with 1 card. And now I have 1 open slot free. ( I have a riser card with a 4th slot on back side )
I'll mess with it more tonight / this week. I think it has latest firmware and such but could be wrong.
I created a number of issues on github for you to track.For proper follow up, maybe you can add a bug entry on the GitHub ?
I ma having trouble trying to get adlib support going, the LED on the sound card/chip is red, and I am using the following pin outs on PicoMem 1.11 Board to Sound Card/Chip:
VSYS/5V -- VIN
GND -- GND
GP28/TX -- LCK
GP26 -- DIN
GP27 -- BCK
GND -- SCK
In the PicoMem I had both options under audio set to on.
I purchased these from Aliexpress a while back. They look the same, I just used the female-to-female pin connectors that came in the package, the board does light up RED, and I downloaded the adlib jukebox, it has a test file and it says it is playing but no sound. Are you using headphones or powered speakers? it should work with either albeit low sound with no powered headphones. I am wondering if these need to be programmed somehow? Kind of doubt it I don't see any eprom capabilities on the device.View attachment 1282288
That seems correct. I got one if these and plopped it right on, turned the adlib support on and it worked without any hassle for myself.
I too have the 1.11 board.
great catch. looks like the DACs I ordered already use this jumper configuration, but I will be on the look-out.I found out the issue, you have to set the jumpers on the back of the card via solder pads. Found info @ https://github.com/polpo/picogus/wiki/Building-your-PicoGUS
Hi, did you get EMS working reliably on the Book8088? I missed where you used the LoTech driver. I was able to get the PicoMEM driver to load and do something but the system has a hard-lock or 'divide overflow' within a few seconds of booting DOS (if it even finishes booting). UMBs are working great but It'd be really neat to see an XT showing >1MB RAM just for fun or to try running Doom8088. Which PicoMEM BIOS settings are you using (EMS port, etc) and what config.sys/driver arguments? thxGot my PicoMem v1.11 board today!...
