The link worked for me - it took a while, but it finally succeeded. It is a PDF file, so make sure you have a suitable reader.
Now, onto something less pleasant.
I need to remind everybody to use the private message system for messages that are not of general interest to the rest of the group. The last post about the page being blank probably should have been sent privately, and if it truely was blank then a correction could be publicly posted.
Also, if you .sig is longer than your message, you probably shouldn't have posted the message.
Lets try to keep the noise to signal ratio to something tolerable.
