MindWalker
Hi.
I am trying to use a PiSCSI device to emulate an external SCSI drive on my Sparcstation 4 to use ISO images of software for the machine. I have correct cable + adapter to connect them together, the termination is on on the PiSCSI and if I mount a disc (with the correct block size of 512) I can see the CD-ROM drive listed in probe-scsi under SCSI ID 6.
However I can't get it mounting under Solaris 2.6. It's not coming up under /cdrom by itself (AFAIK the volume manager should do it automatically) and if I try to mount manuall using commands like mount -F hsfs -o ro /dev/rdsk/c0t6d0s0 (in either /cdrom or /mnt/cdrom etc) it says no such file or directory.
If I look at /dev/dsk (OR /dev/rdsk) there are only files referring to the SCSI ID 3 (the system drive):
whereas I believe the CD drive should be c0t6, so the system doesn't appear to see it at all?
What am I missing? (I know I can make a .tar archive, move it over by ftp and untar it, but I am a bit short on space and also this is somewhat slow)
Bash:
# ls /dev/rdsk
c0t3d0s0 c0t3d0s1 c0t3d0s2 c0t3d0s3 c0t3d0s4 c0t3d0s5 c0t3d0s6 c0t3d0s7
