Problem when I decompile a .OBJ file (Victor 9000 BIOS)
FreddyV
Hi,
I am working on the Victor 9000 machine, to rebuild a BIOS and eventually build an XT IDE board for it.
I found the .OBJ Files from the BIOS and the DOS and when I try to decompile them, there are some missing code.
Example:
mov word ptr $S16,bx
mov word ptr $S16 + 00002h,es
db 089h
in al,dx
pop bp
Or :
mov cl,0Fh
mul cl
db 089h
ret
les si,dword ptr JPTR
db 089h
repz mov al,es:[bx+004h]
mov $S31,al
What are those DB 89h opcode ?
Do you know a good OBJ 2 ASM program ?
Thanks
I use this OBJASM, I don't remember where I got it:
; OBJASM version 2.0 released on Jan 3, 1991
; (C) Copyright 1988,1989,1990,1991 by Robert F. Day. All rights reserved
What about disassembling the ROM itself?
This seems to be one of those machines where the BIOS isn't present on a ROM but loaded from disk when you boot DOS... hence, the MSDOS.SYS suggestion above.
