Hi,
I am using 2 x 3V coin batteries to replace the 4 x 1.5V for the real time click of my Amstrad 1640. It seems like the 6V reach the motherboard, but still it does not keep the date after complete power off. I also use a fuse and a diode (to block incoming tension from the motherboard and to reduce voltage), but I do not think these are the source of the problem.
There is Non-Volatile RAM (NVR): https://www.seasip.info/AmstradXT/16.../section1.html
Do I need a specific "date" program provided by Amstrad to set the date permanently?
The battery is not used while the system is on, which means the computer must switch quickly to the battery once powered off. Maybe this does not work or it happens too slow?
