Aeroraptor
Hi all,
A friend of mine has a PS/2 8525, specifically type 25-004, that he wants to get some files off of. Problem is, around 1996 the floppy drive started to quit, so he never got all of it off. My first instinct would be to just remove the hard drive and put it in another PC, but unlike the 25SX the 25-AT (8086) doesn't use IDE, it uses a weird IBM proprietary pseudo-IDE thing. So I took the floppy drive out and found the first problem, the foam head stop was totally loose and flying around, so I took it out. I then got some rubbing alchol and cleaned the heads lightly, but it still does the same thing when you try and boot it. It clicks the drive once, the light briefly lights, and then it gives the abort/retry/fail error.
Any idea what I can do to get this thing off the ground? I'm having tons of problems sourcing a new/used one...
John
John
