matthew180
Greetings,
I need to back up an ST-225 that currently has an Adaptec ACB-4000A card attached to the bottom. I had never heard of such a thing but once I learned it was an "Winchester" to SCSI adapter I though "no problem", SCSI is backwards compatible, and I just happened to have a PCI host adapter with a 50-pin connector and BIOS utilities.
However, after hooking everything up, letting the ST-225 spin up and the ACB-4000A do its initialization, I would start the PC, enter the SCSI host BIOS routines and scan for devices. Needless to say the drive is not recognized. So I figured maybe the host adapter was just too new, so I pulled out an older (circa 1988) ISA based host adapter (my motherboard is old enough to have 1 ISA slot), made a DOS boot floppy with drivers, and tried that. Alas, even the older SCSI host does not find the drive either.
I then thought I could just remove the ST-225 from the ACB-4000A and plug it directly into an old MFM controller; let's see where did I stash that 286 I had 12 years ago... I don't have my 286 era hardware any longer and finding a box that's newer than an XT but older than a 386 is proving to be very difficult! But that's another story all together.
At any rate, if I could just read the disk via the ACB-4000A I'd be all set. I do know it works because it is out of a dedicated computer (part of a 3-axis winding machine's PLC) and it works in that environment. Well, kind of, the drive is starting to blow errors (go figure, it's only 24 years old), thus my needing to back it up and get it replaced.
Any insight would be greatly appreciated!
Thanks,
Matthew
Thanks,
Matthew
