I received a floppy with a Tandy 200 some time back that that is for TS-DOS (a disk operating system for the TPDD from Traveling Software). At the time, neither the computer nor the TPDD that came with it worked. I finally got around to fixing the Tandy Portable Floppy Drive (belt replaced) and I have another T200 that I obtained recently with only a few issues (backup battery needed replacing and a trace was gone from a pre-existing battery mishap), that I also fixed. Now that I have a working system, I wanted to try and read the disk.
The floppy drive works fine with the Utilities that it came with (formats, reads, writes, backups), but I would like to be able to read the TS-DOS installation disk, unfortunately, it is warped and won't read (IO error).
SO - does anyone know how to fix a warped floppy? (take out the interior and move it to a non-warped outer casing?) I'm guessing that it was subjected to attic heat or some similar incident to warp it.
Is there another way to get the software off the disk?
is TS-DOS worth going through this effort?
