So, in the photo, those switches did not work, *until* I reflowed the solder and then all was ok. Many others will report a similar story. Again, with the kb where the caps can be removed. Yours may be shot as you say, but if you have that kind of keyboard, it is worth reflowing the solder on the underside before having to remove them.
