replacement for 80286
That seems rather low, too. I also get a score of 23 on my Compaq DeskPro 286/12. Could be they ran without the cache enabled as well? BTW, your 80286 is 8 MHz as evidenced by the 16 MHz crystal and benchmark results, not 6 MHz as you labeled it. Not a big deal, I wasn't sure you were aware of it or not.
Hello, you are wright - it sould say amd286-8mhz. :)
/cimonvg
Hello
i did some tests.
AMD286-6mhz - to compare against:
;Data collected by: TOPBENCH | Benchmark and detection stub | Version 0.97
;This file contains fingerprinting information about your computer. Please
;email this file to trixter@oldskool.org with a subject line of "Benchmark" to
;help test these routines and seed the TOPBENCH database.
[UIDF102A099F]
MemoryTest=924
OpcodeTest=398
VidramTest=779
MemEATest=515
3DGameTest=386
Score=16
CPU=Intel 80286
CPUspeed=8 MHz
BIOSinfo=R(C)1985-1989, American Megatrends Inc,.All Rights Reserved.1346 Oakbrook Drive, Suite-120, Norcross, GA-30093. Phone-(404)-263-8181. (04/30/89, rev. 0)
MachineModel=01FC
BIOSdate=19890430
BIOSCRC16=F102
VideoSystem=VGA
VideoAdapter=VGA, Paradise PVGA1A, 8-Bit-Video, 8-Bit-ROMfixed-sync, 512kb Vi
Machine=AT clone
and the MakeIt486 (no cache enabled):
[UIDF1026E7]
MemoryTest=769
OpcodeTest=372
VidramTest=787
MemEATest=491
3DGameTest=358
Score=18
CPU=Cyrix/TI 486-class processor
CPUspeed=33 MHz
MachineModel=01FC
BIOSdate=19890430
BIOSCRC16=F102
VideoSystem=VGA
Machine=AT clone
and at last the "new" Nokia-module:
[UIDF102920]
MemoryTest=1048
OpcodeTest=396
VidramTest=771
MemEATest=527
3DGameTest=401
Score=16
CPU=AMD Am386SX
CPUspeed=8 MHz
MachineModel=01FC
BIOSdate=19890430
BIOSCRC16=F102
VideoSystem=VGA
Machine=AT clone
..i had to build some socket extensions , but after i firm pressure the Nokia-module did connect to the motherboard ;)
The speed of this "new" (a call it new - i have never used it before :D ) nokia-module is not doubled. But the feeling , when used in PCDOS is better then the MakeIt486 (without cache enabled) !!
/cimonvg
I guess this further supports the assertion that a 386sx really isn't any faster than a 286 at the same clock speed. The 486 is really hurt by the lack of cache. Even that early on it's obvious how important it was to keep the CPU fed.
There's always babyAT motherboards. I dropped one into my XT clone back in the day. A tight fit under the A: drive housing, but it worked well.
When going through my stack of boards I happened to find a board that has a 386SX: not soldered but using a socket. Because this board was not of the usual AT format, wrong placed holes and LPT/COM port at the end of board, plus it needed a not-standard riser board to attach cards, which I didn't have, so I decided to use this CPU for my project. To be honest I never paid that much attention to the pins but now I see that they are small, IMHO really to small to solder them using a normal soldering tool :(
Just another challenge, I think....
