Pins in the 15-pin VGA plug.Also, the reason why I need to replace this cable is because there were so many pins broken at the end that it not longer worked.
So another option is to find someone with requisite soldering skill to do that for you. Did you record which wire went to which pin in the 15-pin VGA plug?I spliced apart the end of the cable and attempted to join it with the end of another VGA cable, but this was far to fiddly for me to deal with atm.
