Repro SCELBI interfaced with Popular Electronics Scopewriter and ASCII keyboard
mwillegal
This is something that was done back in the day and I felt that I had to recreate this combination of devices. I also have a little 256 byte monitor hacked together. The monitor supports reading and writing memory and executing programs through normal keyboard input. These add ons turn the SCELBI 8H into a machine that approaches practical usefulness. More details can be found on my blog.
http://www.willegal.net/blog/
Regards,
Mike Willegal
Very nice, nothing like an analog X-Y display. Too bad analog scopes are getting older and AFAIK aren't being made anymore. That output on a digital scope looks bad (I've tried).
I've build a Spacewar display for my PiDP8 and used a (fairly rare cheap) Tek 604 display in great shape for it. It's far better in resolution and linearity than my in rather good shape 464 (which is a relative of your 465). Being a few inches larger helps. I have a few Tek 620's with dubious aging tubes and/or bad switching transistors, but the working ones were noticeably better than the 464.
You always read about projects involving converting a CRT TV to an XY display, but few have actually done it (and lived, apparently). And then, I wonder about the frequency response and linearity.
The Scopewriter is not, strictly speaking, an X-Y display, as it only draws in the X axis. This makes it a vastly simpler solution than some others, at the cost of supporting only one line of output.
The SCELBI CRT interface does draw characters in an X-Y fashion. It is interesting in that it does this with two OP-AMP integrator circuits, one for X, one for Y. The main problem I have with my Tek465 in this application is that the Z input is capacitor coupled and reacts a bit slower than would be optimal for the SCELBI CRT interface. The thing I like about the Tek 465, is that when something goes wrong, it seems to be quite repairable, and as it is 40 years old, I do have an occasional issue with it. I agree that many other scopes have better display resolution.
regards,
Mike Willegal
I bought a broken 464 as a parts source for my good one. Then I repaired it. Diode bridges, of all things. These were among the last TEK oscilloscopes without (for the most part) unobtanium semiconductors.
