rimmeruk
Good New Year to All!
I've replaced the tired TFT VGA color screen in old laptop (Amstrad portable) with an almost identical screen. I was unable to find an exact replacement.
Using the datasheets for the new panel, I have managed to wire it up to existing LCD cable and I've got a colour image. The original TFT panel
was 3-Bit RGB data signals for R0-R2, G0-G2, B0-B2. The new panel is 6-Bit RGB (supports more colors) with data signals R0-R5, G0-G5, B0-B5.
I'm not bothered about having the extra colors, just the standard 256 that the original had is more than enough for the vinatge software that I use.
Because the older TFT screen cable does not support 6-Bit colour, what is the best or correct way to wire the 3-Bit RGB data wires to the the 6-Bit RGB data wires?
At the moment there are some strange color artifacts and interference which I think may be caused by the extra 3 RGB data signals being unconnected or floating.
Not really sure how to wire the extra 3 bits of color signals from each RGB channel., I've tried tieing them to GND but the display image becomes very dim.
Here are the pinouts for each of the panels signal connectors.
Original Panel with 3-Bit interface
New Panel with 6-Bit interface
Thanks for reading.
Thanks for reading.
