EverythingIBM
So I recently ordered some parts to get a perfect cosmetic AS/400e (system type 9046). It's the 170 variant. The base system is still in the mail. I don't believe it has a tape drive, but I don't care anyways because I wouldn't have tapes for it. That will be an issue if I need to do a backup of the system-- which presumably could be used to redeploy everything on different HDDs. Another worrying thing is the whole OS licensing... going to have to figure out how to extract the license from the existing installation.
After doing some research, I noticed there was an S3 PCI video card FRU. Now, it is presumable that said video card has a POWER BIOS instead of x86. I am going to try to get a 3dfx PCI card weaseled into the AS/400e-- I am hoping if the x86 BIOS doesn't work (which will most likely be the case) if I can put on the mac POWER BIOS.
I was finally able to get the manuals for the system, presently glossing over them. It's quite interesting, uses a netfinity daughtercard to run the webhosting elements. Another thing to note is that it uses PAPST fans, unusual for late 90's systems. Too bad intellistations don't use PAPST...
Because I am going to mod my Model F 122, I will not be buying an infowindow. Going to do my best to get the terminal-ing done over the ethernet card. Don't really want to use a discreet terminal anyways.
Anywho, I'll report back here with the results of the science experiments.
