Scelbi eprom set
livewire
I am building a SCELBI 8B, I am searching for a set of programmed 1702A EPROMS.
I believe there are 16 pieces required to populate the SCELBI PROM board.
Can anyone tell me who might be able supply these? :confused:
You can pick up parts at Unicorn Electronics. I don't know if he has blank parts and how "good" they are. I'm not interested in becoming a component dealer, but I have built a Martin Eberhard 1702 programmer and can burn the parts for you.
regards,
Mike Willegal
Seems the Unicorn Electronics have the 1702's for $8 each, so that equates to $128 for the 16 before shipping or taxes.
http://www.ebay.com/itm/QTY-8-EPROM...898592?hash=item5b375d80a0:g:PNcAAOSwX61ZBlSr
that ebay listing is for lot of 8 pieces for us$19.95 or offer. And there are 4 lots of those 8 pieces available.
So that in my thoughts is a reasonable deal, if you get 3 lots for $60, would allow for some failures. Mind you these are S/H and you are not it appears guaranteed they are all the same speed.
The other point is it may be worth getting some cheap s/h ones till you get design built, tested and working, then go out hunt and collect 8 of the old ceramic ones. They look way more the period look you could hope for.
There are white ceramic packaging, and the 'green' ( I know that's not the correct word, but I am tied) look.
Look at these
http://www.ebay.com/itm/Very-rare-v...hash=item2a1aeb6c40:m:msL0Z7q3jt7rWOro0l0evnA
and these
http://www.ebay.com/itm/Intel-HC170...307364?hash=item4402b6c064:g:dtYAAOSwFdtXx5Gv
There seems to be a variant on the Ceramic packs. ie type 2, type 7 and some others. You will need to research what you need
Thanks for the detailed replies guys!
Mike, I will email you to discuss details.
inotarobot, I like your thinking. I was actually thinking the same thing.
I am going to start out with the newer grey ceramic eproms, then in the future
graduate to the "first style" of the white ceramic C1702A, the one with the square window
