AngryWhiteGuy
I'm back in business again; the drive needed a re-initialize (see Demon Possessed 1541 thread) to get the heads back in line. Cool, now back to getting IDE64 configured and running....
What kind of garbage? Are those original games or copies? Many cracked games come with a decrunching routine that will execute for a number of seconds. During that period of time, a number of apparently random characters may appear on screen, the border might flash, strange noises could be heard etc. Eventually the program would run a cracker intro screen or similar. Some of the freezer cartridges also temporarily corrupt the screen while restoring the dump.
I'd recommend you to hold your breath and wait for 10-15 seconds of garbage and noise before giving up. On the other hand, perhaps you have already waited for so long but with no improvement. It could be bad RAM that makes the program failing to decrunch?
And the computer should run fairly well without a SID chip too, so it will be easy to determine once you have pulled it if that is your only problem.
