Seikosha SP-1000AP DIP Switch Settings?
jmetal88
Derby, KS
Does anyone know what the DIP switch settings for the Seikosha SP-1000AP are? I'm trying to go through and test all my Apple II stuff, but I'm having trouble with this printer because I don't have the manual for it and have no idea what the DIP switch settings control or where they need to be set for my setup. I thought it could possibly use the same settings as the ImageWriter (as it's supposed to be ImageWriter compatible and the switch groupings are the same), but I tried to set the switches according to that documentation and it didn't work. I can get the printer to go into a self-test mode by holding down the "Line Feed" button while powering it on, but I'd love to know if the serial port on the back is actually functional, too.
Thanks!
I hope I find it worthwhile using this printer, because I just went on a day long repair session that started with an attempt to clean what I thought were stuck pins and ended with completely disassembling the print head so that I could re-solder wires that had somehow broken off a couple of the solenoids. xD
I apologize for the 5 year bump but I've found myself in the same predicament. I just bought this printer and the DIP switch settings don't seem to be documented anywhere online.
Would anyone with a manual be able to provide them?
Don't know if SP-1000VC is the same as the SP-1000AP, but these are for the VC:
1: Device #. ON=5 / OFF=4
2: Page length. ON=12" / OFF=11"
3: 1" skip-over perforation. ON=valid / OFF=invalid
4: Slashed or unslashed zero. ON=unslashed / OFF=slashed
