Paradroyd
I use my TRS-80 model 4 for BBSing quite a bit. I've been using the Ethernet and tcp/ip stack with the included telnet app that came with the M3SE, which works pretty well, but it's a bit limited in that some BBSs don't like the telnet protocol. As far as I can tell, the telnet that came with the M3SE can't do raw tcp, so i have to do things like hopping through intermediate servers (usually a Decserver and/or Raspberry Pi) to strip telnet out of the mix. This is a bit of a hassle. Plus I'd like to use some of the dedicated terminal programs that only talk to a real serial port (I'm assuming I can't re-direct serial to tcp ports from LS-DOS). I also have a HiRes graphix board, so I'd like to be able to use ANSIterm, which seems to be strictly serial.
My model 4 is a non-gate array model 26-1067, which didn't ship with a serial port or floppy controller, and originally had only 16K (it's since been expanded to 64k).
After watching Ebay for a while, I found and bought a serial interface. It looks a bit rough, but it also looks very serviceable. If it doesn't work day one, I think I can probably fix it. I'm including pictures of it in this post.
I haven't been able to find exactly how the card gets mounted to the main board. I have a general idea, just not the specifics. Besides the physical mounting of it, it looks like it's supposed to attach electrically to the top of the main board with some kind of semi-rigid ribbon cable. It looks like 20 conductors. I don't think that that was included with the card, so I'll have to find one somewhere, or rig something up. Any info on what this cable is, where I can get one, or what I can use instead would be helpful. also, any tips on the physical mounting of the serial board (it may be completely obvious, I'll have a better when I actually get the serial card. Looks like I should have it in a day or two).
I'll have to tie into one of the power supply connectors too to power the thing. Looks like a standard cable with a couple of 4 pin connectors for that.
Thanks for any info in advance.
