| VCF SoCal | TBD, 2027, | Southern CA |
| VCF East | TBD, 2027, | InfoAge, Wall, NJ |
| VCF Latam | TBD, 2027, | Bahía Blanca, Argentina |
| VCF Pac. NW | TBD , 2027, | Tukwila, WA |
| VCF Southwest | TBD, 2027, | Westin Dallas Fort Worth Airport |
Aha! Your rails are binding. Clean and lube them. Hopefully this simple.![]()
You think? I tried that before. I'll do a bit more, any particular areas I should target?
I also tried adjusting the speed and then I started to get Format Speed Error. I've since moved it back
So this little program produces the following output.
20 READ ERROR 78 1
I would test for coils continuity on the top head first, then try to slightly increase the head pressure. It would be good to have a picture of the head mounting (you need to remove the metallic screen) on this mechanic.
Frank
Definitely starting to get our of my comfort zone. How would I go about "test for coils continuity"? I have a volt meter but would not know where to start. thanks!
When taking the readings is the unit powered on and idle?
According to the schematic I've found on zimmers:
Locate U10B and U11B, DA1 or DA3 and DA2 or DA4 or R1 and R2, obtain an ohmeter, then:
head 0: measure resistance from pin 6 of U10B to pin 13 of U11B, to pin 3 of either DA1 or DA3 and to pin 3 of either DA2 or DA4. If DAx are not easily accessible, measure to each end of R2.
head 1: measure resistance from pin 5 of U10B to pin 12 of U11B, to pin 1 of either DA1 or DA3 and to pin 1 of either DA2 or DA4. If DAx are not easily accessible, measure to each end of R1
Ok so I may need some more guidance here. After reviewing the schematics and analysing the board I believe I have found the area that needs to be checked. But still not sure what I am doing I can't seem to figure out the pin orientation.
I ran out of time but here is where I am at:
- I was able to get readings on certain PINs from 10B to R1 and R2
- However I would only get a reading for a second or two. is that normal?
- Without flipping the board over I can't get a contact to anything on DA1 or DA2 or 11B
- My multi-meter was set to 200 ohm scale is that correct?
Ok, looking at the photo and the schematic:
green should be the erase coils,
white should be common connection.
So basicly for each head, you should have 10-16 ohms between white and any other color excluding black.
Frank
So assuming I have done this right, here is what I got.
10B Pin 5 to R1 - 18.7 and 18.5
10B Pin 6 to R2 - 18.1 and 19.2
On the drive head - White (middle) to:
Green: 3.5
Red: 17.5
Yellow - no reading - it shows something on the meter but only for half a second
Black: 16.8 - I know you said excluding, but I took it anyway.
Thoughts?
