SimH throttle speeds versus actual PDP-11 systems?
tschak909
Denton, TX USA
Has somebody put together notes or a table on matching throttle speeds to approximate CPU speeds of DEC systems for SimH?
I know it's not exact, but am curious as to just how accurate we can get?
-Thom
simh on Xeon E5680 3.33 ГГц
LSI 11 or PDP 11/03 Processor
56KB of memory
50 Hertz System Clock
No SYSGEN options enabled
.RUN SPEED0
Speed test (cache absent)
BR .+2                      64 031 600  оп./сек
R1(23456.)+R0(12345.)       ... ->  27 350 088  op/sec
KDJ11-B (24 MHz)
Testing in progress - Please wait
Memory Size is 4088 K Bytes
9 Step memory test
  Step 1 2 3 4 5 6 7 8 9
Message 04      Entering Dialog mode
Commands are Help, Boot, List, Setup, Map and Test.
Type a command then press the RETURN key: MAP
23.996 MHz
Memory Map
Starting   Ending       Size in    CSR          CSR     Bus
Address    address      K Bytes    address      type    type
00000000 - 17757776     4088       17772102     Parity  PMI
Press the RETURN key when ready to continue
Type a command then press the RETURN key: BOO DU0
Trying DU0
Starting system from DU0
RT-11SB  V05.07
.R MSCPCK
.RUN HX7:SPEED4
Speed test (cache on)
R1(23456.)+R0(12345.)           ... ->   5 989 094 op./sec
56KB of memory
.RUN SPEED0
KDJ11-B (24 MHz)
9 Step memory test
23.996 MHz
Memory Map
Trying DU0
RT-11SB  V05.07
.R MSCPCK
.RUN HX7:SPEED4
would you be able to share these benchmarks or where they can be found?
