Hi folks,
I have managed to get hold of a PC200 and currently have it working with the TV output.
The picture is flickering quite badly so I am unsure if is the TV I am running it on, or the modulator itself.
I actually had one when they were first out and the TV picture from the built in modulator was rock solid so I know it was originally capable of a decent picture.
I have tried to connect it to the same TV via a VGA cable but the PC output is 9 pin and the TV 15 pin, so I tried the simple option of using a 9 pin to 15 pin lead and what I thought were appropriate DIP switch settings.
This unfortunately didn't work.
Can anyone advise if this is possible in terms of configuration and if it is, what the DIP switch configuration should be?
Thanks,
Rich
Thanks,
Rich
