The PPro stuff is interesting. Perhaps it's the micro-op conversion then? I've used a Pentium III extensively under DOS and 98SE, and under 98SE it's fine, but under DOS things seems sluggish. I've done timing comparisons, as I said, and they're at least as fast, but something is different. Maybe I've looked at it the wrong way all along - perhaps it's not the CPU at all, but the video system?
I know about Zeno (designed to speed up video output on PPro+ iirc), but I don't think that fixed the effect I describe. I was convinced it was the CPU, bar none, for a long time, which is why I blamed the PPro and it's descendants - maybe I was wrong. Since I assumed this, I focused all of my research on the 486, Pentium, K5, K6, P2, and PPro architectures, to see what the difference was between the old and the new. The two things I found were that there was a focus on 32-bit optimization on the PPro and above, and the PPro had a RISC core with a translator to take normal x86 instructions and translate them into little micro operations which are then executed out of order, to increase efficiency. My theory was either that the lack of optimization caused it, or the micro-op translation caused it. The K5 and K6 were based on a CPU by NexGen that used the same RISC core concept as the PPro, so they wouldn't be any different, or so I theorized.
I ended up using a Pentium 3 for two reasons - one fell into my lap that week, and I also theorized that if the micro-op translation OR 16-bit optimization was the difference, perhaps just jacking the raw speed up as far as possible would negate the effects and at least feel as snappy as a 486 at 66Mhz. I set up my 1ghz P3 box, but no, it still felt sluggish.
In retrospect, however, after your (everybody who's talked about it's) input, I'm beginning to think that my base assumption was flawed/premature, and perhaps the video card/subsystem is to blame. Perhaps a PCI video card, while faster or more powerful, is not as snappy as one that was designed when DOS was dominant? I'll need to perform some new tests - I'll set up my midrange Pentium box with a PCI card, and see if it feels sluggish. Then I'll set up the newest box I can find that has ISA slots with an older ISA video card, and see what that feels like. Perhaps even a Pentium box would exhibit the same sluggishness to me, because I almost always use 486 boxes to play DOS games and use DOS, and use VLB in those cases. I've not read extensively about the workings of VLB, but perhaps it's closer ties to the CPU provide that snappiness I'm used to, regardless of card power/speed?
Thoughts?
You lucky bastard! LOL. I'm sure you know how rare those are and how lucky you are to own one.
I envy you for that, heh (not that plenty of things on that list don't make me envy you, but the V55 above all others..).
(As an aside, I found a picture of FOUR 5500s in SLI!
http://www.3dchip.de/Grafikkartenmodds/Grafixmodds/quantummercury.jpg Damn do I wish I owned that - I'd put it in a brand new box and it might even keep up well enough to be usable with modern games - 16 cores after all...
Thoughts?
Voodoo 5 5500
