Scali
Perhaps some of you were aware that this past Easter weekend, the world's biggest demoparty was on: Revision.
There was one release for 8088 there, it was a chipmod song using the sound routine that reenigne originally developed for the endtune of 8088 MPH. The rules required that the executable be 32 KB or less. Of course we can pack 3 minutes of music in there just fine
Perhaps you like it. This will run on a real IBM 5150 or 5160 provided you have enough memory (I suppose 256 KB should do it, perhaps slightly more).
I also created a 'safe' version that requires a slightly faster CPU, but uses the PIT for timing, and is therefore not sensitive to the speed of the system. This makes it more friendly for clones and emulators.
Binaries can be downloaded here: https://www.dropbox.com/s/l6s4f3bigilkoz8/SIZEMTRS_drums.zip?dl=0
