aysel
Hi all,
Just thought I would make a short post about this interesting little upgrade as theres very little available online for its use with Amiga's.
I have been hunting one for almost two years and then two cropped up in the same week so I grabbed them.
The Sonnet Quaddoubler is a small PCB about 2inch x 4inch which has a Motorola 68040 mounted on it. I always thought they were overclocked 40 mhz chips but the two I have are both full 040 50mhz chips with a slight overclock to 57mhz. After a bit more research this makes sense as the Quaddoubler used must be a multiple of the bus speed of the accelerator, the commodore A3640 is 25mhz so CPU must be 50mhz.
To install I just removed the 040 @25mhz from my Commodore A3640 accelerator and plugged this board in its place. If you are looking to use one with the Amiga then you just need to make sure you grab one which has the pin layout such that the Quaddoubler mounts parallel to the A3640, otherwise it wont fit back in the case!
The performance increase is fantastic for such a small outlay, Sysinfo now puts my machine at 37.7MIPS... up from 18.8! It doesn't resolve the motherboard RAM bottleneck the A4k suffers from but for my needs (games and demos) 37.7MIPS is an outrageous amount of CPU grunt
The A3640 removed from my A4k with the stock 040 25 still installed
With the Sonnet installed
Back inside the A4000... snug fit :D
And the obligatory Sysinfo shot... its gone from 4.7 MIPS with the original 030 @25mhz to 37.7MIPS with the Sonnets 040 @57mhz
I tested it by running Frontiers intro for three hours and its still super cool so overall very pleased. Amazing to think Sonnet never provided these or offered any support directly to the Amiga community and always promoted them solely as a MAC accelerator...
My Homepage - www.urbecks.com
