I have a nice 5150 system, 16-64k mainboard, original power supply, original 10MB HDD (with only 1 bad sector!). The system is beautiful minus the constant squeak from the 10MB HDD. It sounds as though it could come from one of two locations and I haven't been able to "put my finger" on it.
I'm 99.9% sure it's not from the heads / platters contacting each other, but it is either from a "shoe" that touches the side of a metal cylinder under the HDD enclosure (between the two circuit boards) that spins with the main motor. Two leads come from this "shoe". It doesn't look like it's a brush for a DC motor, but I'm sure it fulfills some function. The other potential source is a small metal clip that touches the center of the spindle by the circuit boards.
I have tried to lubricate both areas and that makes the squeak go away for a few minutes, but it always comes back.
Any suggestions on what lubricant to use or what to replace / fix to deal with the squeak?
