hey all! i have a first gen pentium PS/2 that i am currently having trouble getting OS/2 installed on, i am completely stuck at the moment and would appreciate any guidance
i have tried both original warp 3 install media and newly written warp 4 media but the issue is the same for both: i am able to progress through fdisk and partition my disks, and even reboot to select my newly created C: partition, but when the installation gets to "loading system files" it invariably gets stuck. i have removed everything but the bare necessities (SCSI, VGA, CPU, RAM) from the machine, but it still does not work. pressing alt-F2 does not show it getting stuck loading any drivers at that stage, it seems that everything necessary is already loaded and working by that point. there is no activity on any of the drives during this time as far as i can tell, and even given 10-15 minutes or so the installation never progressed beyond that screen.
i do not suspect hardware as the machine has a working OS/2 installation, but it is quite old and messy so i am trying to start fresh after backing up all the important bits. i am unable to run arcaOS as the machine has 32MB of RAM at present and i do not think it can even support the minimum 512MB that arcaOS wants. none of the cards are particularly exotic, the SCSI adapters are IBM fast/wide SCSI-2 cards and the VGA is just a standard IBM XGA-2.
thank you in advance!
