dfnr2
Hi All,
My replica keyboard (see this thread) has an uppercase/lowercase keymap. It works, but has not yet been optimized.
The shortcomings are:
- The N^ key and P@ key are now nN and pP, so the ^ and @ characters need a new home
- Currently the POWER key/light is being used as a capslock.
- It seems the REPEAT key could be replaced, as there is already an autorepeat function, and another keycap could be placed in that spot.
- The N^ and P@ could be reverted to the normal N and P keys, which are included with the keycap set.
- The right and left arrow keys could be overloaded with SHIFT and CTRL functions.
- Currently, CTRL+RESET is required for a reset. If there were enough demand to have a jumper-selectable plain RESET, then the simplest solution would be to add a new keymap (or set of keymaps) with the plain RESET key mapped ot the RESET function. The desired keymap would then be selected by jumper or DIP switch settings.
- At the moment SHIFT+RESET produces a CLEAR pulse for the apple I. Any suggestions for a different mapping?
