pkhoury
This is what I get when I try to start up. Without memory, it hangs at the exception. I'm presuming Tsunami is the CPU itself. I'm not sure if this is something that can be solved with capacitor replacement or not.
MMU Context Table Reg Test
MMU Context Register Test
MMU TLB Replace Reg Test
MMU Sync Fault Stat Reg Test
MMU Sync Fault Addr Reg Test
MMU TLB/CAM NTA Pattern Test
D-Cache RAM NTA Test
D-Cache TAG NTA Test
I-Cache RAM NTA Test
I-Cache TAG NTA Test
FPU Register File Test
FPU Misaligned Reg Pair Test
FPU Single-precision Tests
FPU Double-precision Tests
FPU SP Invalid CEXC Test
FPU SP Overflow CEXC Test
FPU SP Divide-by-0 CEXC Test
FPU SP Inexact CEXC Test
FPU SP Trap Priority > Test
FPU SP Trap Priority < Test
FPU DP Invalid CEXC Test
ERROR : FPU Exception Did Not Block Store, addr = 00600000, exp = 00000000, obs = 0f884010, xor = 0f884010
U-NUMBER : Suspect Tsunami Module
Allocating SRMMU Context Table
Setting SRMMU Context Register
Setting SRMMU Context Table Pointer Register
Allocating SRMMU Level 1 Table
Mapping RAM
Mapping ROM
