Hi all,
I've got a Sun Ultra 5 which has been sitting on a shelf for 10+ years. Last time I used it I put Gentoo linux onto it and it ran fine. 128MB of RAM installed; nothing further added to the system.
First problem I had was that the NVRAM internal battery had gone flat. I got out the dremel and found the contacts on the rear of the chip. I also drilled in further and cut the contact where it meets the battery (I didn't want the external battery connected in parallel with the internal). Soldered everything together and it now holds its settings just fine. I reset the NVRAM and entered the MAC/system ID's. No errors are reported when switching on now.
The IDE HDD inside is no longer functional so I installed a 320GB IDE drive I had lying around. I think the system picks it up fine as it complains that the 'magic number' on the HDD is wrong (which makes sense as the drive is blank).
My problems start when trying to install linux on the machine. I burned a couple of different debian versions (7.1 and the latest 9.0) for the SPARC architecture. The machine hangs when I turn it on trying to boot from the HDD; so I press STOP A then type boot cdrom. The machine then boots from the CDROM and up pops the debian installer. At the boot prompt I hit enter (default to install debian) and it then says:
Allocated 64 Megs of memory at 0x40000000 for kernel
Loaded kernel version 4.15.11
Loading initial ramdisk (14093275 bytes at 0x4400000 phys, 0x40C00000 virt).
At this point the machine locks up. Nothing will free it up (stop A does nothing) and I even tried waiting for an hour to see if it would change. Both versions of debian (7.10 and 9) do exactly the same thing.
I googled for a while on the error but couldn't find anything relevant to me. Anyone able to help?
Also is there a key combo to reset the Ultra 5 when it locks up? At the moment I am power cycling it which doesn't feel right....
