Half-Saint
I picked up this complete system from the dumpster. Something I do pretty regularly and most machines just work but this one is giving me grief. I cleaned everything up and installed a new battery thinking that would be it.
Jumper settings here:
http://stason.org/TULARC/pc/motherboards/U/UNIDENTIFIED-286-SUNTAC-286P.html#.Vd_7WPmqp49
Unfortunately, sometimes it won't POST at all, at other times it boots but hangs while loading DOS. When it successfully loads DOS, it hangs sooner or later. Sometimes it also hangs while in BIOS.
Here's the patient:
What I tried so far with no success:
- replaced the memory with 44C256-80N chips from a different 286 board
- disabled onboard IDE and used a dedicated IDE controller
- removed co-processor
- disabled onboard floppy controller
- turned parity off
- replaced power supply
- replaced video card
Anything else I can do before I bin it?
Cheers
P.S. I noticed memory chips on the motherboard have -80P at the end while the ones I used to replace them are -80N. What's the difference, if any?
Here's the patient:
- turned parity off
Cheers
