Wawavoun
Hello,
I actually work on my 6809 Corsham system.
I have MS-S board in slot 0 and a diy FD-2 floppy interface in slot 1.
I use SBUG 1.8.
A Gotek jumpered S1 is connected to the flat cable (after the cables 10-12 crossing so acting as drive 0) and a real 3.5 floppy drive (a PC 1.44 mo drive) is connected before the crossing so as drive 1.
Flex291 or Flexnet (716 ko image) boot and work well from the Gotek. Also I can write to this drive from XBasic for example.
The problem I have is with newdisk.
I run "newdisk 1" to format the floppy in drive 1.
I use dual side, 80 tracks and double density.
The drive do a lot of job on the floppy. I assume he write on each track then he come back to track 0. At this moment after some seconds of silence i got a error "formatting aborted"...
I have tested two different drives (both working elsewhere) and several floppies (DD, not HD) with the same problem so I think the problem is not here.
If I replace the floppy drive by a second Gotek with a 716 ko image (same as the boot disk) then I can format, write and read...
Any idea where is the problem and/or how can I investigate ?
Thanks and regards.
Philippe
I use SBUG 1.8.
Thanks and regards.
Philippe
