It has really been disassembled. I'm using some JB weld on the hinge parts where the threaded inserts broke away from the plastic mounts.
I found a 1.6G drive that seems to work in it. The BIOS only has two options though, 20M or 40M.
I think I found in the BIOS where the table is though and I might have some OTP EEPROM's I could burn (which doesn't give a lot of option for retrying).
I found a page which shows:
Model BIOS type selection Cylinders Heads Sectors per track Capacity Seek time
Conner CP-3022 Type 11 615 4 17 20 MB (Formatted 21.4 MB) 27 ms
Conner CP-3024 Type 11 615 4 17 20 MB (Formatted 21.4 MB) 27 ms
: ? : Type 12 980 5 17 40 MB (Formatted 42.8 MB) 25 ms
615 cylinders -> 0x67 0x02, 4 heads 0x04, 17 spt = 0x11
980 cylinders -> 0xd4 0x03, 5 heads 0x05, 17 spt = 0x11
Does the 0xE4A0 make any sense? I see the first drive in it, but it lists the cylinders twice (0xE4A1 and 0xE4AD), then the heads at 0xE4A3 and the spt at 0xE4AF.
Then the second drive appears at 0xE4B0.
Any thoughts on why they would list the cylinder twice?
The drive I installed has 3148 cyl, 16 hd, 63 spt.
