LambdaMikel
- Joined
- Jan 25, 2020
- Messages
- 441
Work in progress. So far, a first version of the PCB was designed. I plugs into the Model 1 expansion port via a cable, and passes the edge connector through. It is basically a re-iteration / port of a previous speech synth for the Amstrad CPC (LambdaSpeak 1.99). I'll call it Talker/80 for now - to stay away from any TRS and Tandy in the name. I'll also skip prototyping / bread boarding this time given that I have made a lot of these for the Amstrad CPC, and will make the firmware once I have the hardware built. Let's see how this goes. Will probably need more than one iteration of the PCB. I'll start with DECtalk native mode. Next, I will also attempt VS100 and TRS Voice Synthesizer emulation. DECtalk should be a no brainer - not so sure about the emulations though.
