So i guess that most people that checks this forum section knows of my Frankentandy Tandy 1000 SL.
Although my overclocking goal is a huge success (surpassing my wildest expectations) i've always had some issues since day 1.
So even before i modded this motherboard i was experiencing some tandy video issues. I was unable to run some games that i tried, most notably:
Red Storm Rising
F-19 Stealth Fighter
Gunship
LHX: Attack Chopper
Chuck Yeager's Air Combat
Among some few others but these caught a lot of my attention as i wanted to play these games on this Tandy.
F-19 Stealth Fighter would launch fine, i could navigate through menus just fine, but selecting "Begin Mission" would end in a black screen.
Red Storm Rising wouldn't even pass the hardware selection screen, crashing as soon as selecting the last option.
For these 2 games the solution was simple but that still leaves me wondering. I had to configure the Tandy BIOS to reserve 64KB of memory for video. After that both games (and some few others) started to run just fine.
Gunship i can't even get to run today. With 64KB reserved for video it doesn't even load the title screen. So by previous experience i now increased the video memory to 128KB and now i could see the title screen with music. But after that all i get is a solid yellow screen. Nothing more, even up to today, mods and all (RAM replaced with newer and faster crystal.
LHX is a slightly different case. I should say that all these games actually run in CGA mode just fine (don't remember if i tried Chuck Yeager yet). LHX and Chuck Yeager both have a minimum 512KB RAM required but need 640KB for something else than CGA in full mode. So if one wants to run LHX with Tandy graphics and only has 512KB RAM left, there is a command line argument SMALL that reportedly uses less RAM.
I tried everything to run LHX getting mixed results. I went as far as running the original copy through the disks, booting from a DOS 2.11 floppy to get as much RAM as possible.
So results with DOS 6.22:
With 64KB memory for video and running "LHX SMALL" i get random colored dots on screen and game crashes.
So i loaded DOSMAX with my lo tech 1MB RAM card and now i could load parts of DOS into the UMB area, but despite getting as much as 575K of RAM i get "not enough memory to run LHX despite having more RAM than before. Anyway, whenever i load DOSMAX some games have problems, constantly locking up and complaining there's not enough memory available, so i guess the system does not like DOSMAX.
DOS 2.11:
With 64KB reserved to video i now get the same colored dots on the lower bottom of the screen but the game now plays the title screen although it is rolled horizontally and not centered. Game crashes after title screen animation.
With 128KB for video the colored dots have disappeared and the screen is still horizonatlly rolled and off centre but this time the game does not crash and i get to the copy protection screen.
Has anyone been able to run LHX Attack Chopper in a Tandy 1000 SL with 640KB of memory?? I don't fully understand what is going on. I've though about 2 things:
1- I have a bad video controller; - this doesn't seem plausible as it would have to show the same or other issues in diferent games. Heavy games for a Tandy SL like Stunts or 4D Boxing run just fine. Sierra SCI adventures run fine too. Most stuff runs fine actually.
2- I have bad main RAM / video RAM; - this seems not too plausible as this issue was already present BEFORE the overclock and BEFORE all RAM was replaced, but seems to be the best guess considering what i'm getting.
LHX runs fine in CGA of course. So i don't know what to do, i've tried to roll back the system to its original speed and the problem persists, tried the game in 4MHz and the problem persists. It is a bit of coincidence that i would get bad RAM again after i swapped it all but of course it can happen. I have some newer faster RAM coming my way from china that i ordered 2 weeks ago. I'm using HY53C464-80LS DIP RAM, which is 64x4 just as the Tandy requires. I have 70ns versions coming. I'm not too hopeful this will make a difference though.
So i've been reading through tech manuals to see if i forgot something, went through the IRQ 5 jumper change but that didn't make a difference anyway.
By reading the SL tech manual it seems that the buffer blue chip does have the ability to control 768KB of RAM just like the TL and RL:
Unfortunately Tandy/Radio Shack decided not to included all the needed sockets for 768KB of RAM though. I guess that a TL or RL system won't get my issues, although this does not seem to be only because lack of RAM.
I would like to request all Tandy 1000 SL owners to check compatibility with the mentioned games.
Red Storm Rising
Gunship
LHX: Attack Chopper
DOS 2.11:
