Hello all, I have a Tandy 1000 TL/2 that is virtually pristine on the inside, but unfortunately I cannot get it to work. I don't have a Tandy monitor, so I plugged it up to my IBM 5153 and get the the messed up display like you can see in the attachment. I can faintly make out "Memory Error Info" or something like that in the background. Has anyone run across this before? I'm assuming I have 2 problems -- one with the onboard display adapter and the other being bad memory chips, or maybe it's all one problem. Does it have anything to do with using the IBM CGA monitor? I would try an 8-bit VGA card (or 16-bit card that would function in an 8-bit slot) but do not have one on hand. I'm unwilling to purchase one if that won't fix the problem. Was hoping someone more familiar with Tandys could assist. Thanks!
