Tupin
The Sony drive has a standard connector and four-pin power connector. That adapter gives it an edge connector and a bigger power connector.
Still need help. Either both the floppy drives go on at the same time, only the 3.5 inch drive goes on, or neither go on. There's a cable with a black connector and a gray connector, the 5.25 inch drive has one edge connector, while the 3.5 inch has 2. Which ones go to where?
I don't have a cable with a twist AND edge connectors, will any standard universal cable work? Also, if I use the universal cable, can I just use the 3.5 connector rather than the adapter and a card edge?
