You need MS-DOS 5. I am using the LoTech XT IDE Controller. Mine came pre-assembled for an extra fee. You will be able to use the full size of the card, but with MS DOS 5, you will have a Max Partition size of 2 GB. Also realize the CF Cards are subject to write deterioration. If this is a problem, you can install any AT Class Mechanical IDE Hard Drive you wish.
