FishFinger
Is there any terminal emulator software for DOS which can open multiple connections at the same time on different COM ports, and then let you flip between them?
I'm playing around with some Cisco routers and wanted to be able to plug the console cables into COM1-COM4 and then switch between sessions without having to connect/disconnect all the time.
