necro this thread...
the "FASTEST XT" is the Olivetti PCS86 from 1989 (not 1986 like ppl think)
The PCS86 has a nec v30 8mhz or 10mhz nec v30, 640kb base ram, EMS 4.0
onboard ram ability, bypassing the slow 8-bit isa bus for the extra ems memory, a upto 1.44mb floppy 2 drive controller, a IDE "XTA" 2 drive controller (best to build XTA to 8bit CF adapter
https://www.facebook.com/OlivettiProdestPC1/posts/1606276686257414 for hints), 3 full-length 8-bit ISA slots on a riser card, Integrated Paradise VGA chipset (its 256kb), a RTC with 3.5v battery, PS/2 keyboard & mouse ports, vga port, parallel & serial ports.
Plus 2x 30 pin simms for upto 32mb additional ram (2x 256kb or 2x 1mb or 2x 4mb or 2x 16mb).
nec v30 8mhz may be upgraded to a 16mhz nec v30HL
Its possible to run any version of windows 3.1x if kernel from windows 3.1 build 3.10.034e "janus" in real mode & still access 32mb of EMS ram (although a v30s/8086s should be limited to 16mb ram address, other 16mb will be unusable/invisible to a 8086 class cpu)
TLDR: this PCS86 has all/most ports u need, can be a 16mhz NEC V30HL (100% 8086 compatible + 30% faster per mhz/clock than a 8086) with 16mb usable ram via FAST ONBOARD EMS, access upto 2x 1.44mb floppy drives (or usb floppy emulators), use a CF card as a 8-bit XTA hard disk on onboard IDE (limited to 8-bit even over isa anyways, i suggest ontrack DDO to format card), can run ms-dos 7.10 & windows for workgroups 3.11 in real mode and still see 16mb ram (if kernel from windows 3.1 build 3.10.034e "janus" is used) with ms-dos 7.10 (fat32/lfn support). It could use an isa ethernet card and access the internet via ie 5.01 or opera 3.62, even use calmira II 3.31/camira xp 4.0b for a 95 or xp like shell with lfn support. ISA usb 1.1 cards exist as do drivers for dos/win3.x. that would leave 1 isa slot free for a sound card (unless you like "beeps" only, i suggest soundblaster 2.0), barely fully equipping system to "usable", but usb card might best be swapped for a 1mb (maybe 2 if 8-bit supports it) 8-bit isa video card to max out performance & just ftp files to the pcs86 system
I HIGHLY suggest using the "best possible" 1mb 8-bit isa video card to max out performance & just ftp files to the pcs86 system and not bother with the usb 1.1 card (its no better than using the gotek usb floppy drive emulator anyway)
its as 96% fast a 12mhz 286 with 16mb ram (as both have it on a 16bit bus on the motherboards) & can run windows for workgroups 3.11, if the suggested "mod" is done to the kernel file used. Its useful for mp3 listening, text editing, basic internet/email access, the older dos games like lemmings/prince of persia/wolfenstine3d fixed to 8086 mode (other OLD 286, some 386 era, games fixed in same way, doom???) maybe some ascii rouge likes?
this in my testing is the fastest XT to exist, it can use the 16mhz nec v30HL and has 16bit access to 16mb of ems 4.0 ram, it even has 3 full length isa 8-bit slots so better (read best possible over 8-bit isa) video, ethernet and sound are possible at same time...using onboard XTA (with a real XTA hdd or a custom made XTA to CF card in 8-bit mode adapter) is just a fast if not slightly faster, as an 8-bit XTIDE card (ATA). Very rare, very powerful...just able to run wolfenstine 3d, fixed for 8086, at 320x200 full (not shrunk) and feel very playable.
