ThinkPad 770 ED & 192 Error
lyonadmiral
Peru, New York
Good Evening (or whatever time of the day it is when you are reading this)
According to the HMM 00192 is a CMOS battery error/failure. I've replaced the battery with a brand new CR2032 (Energizer).
Upon a cold boot the system doesn't indicate the failure, it only indicates the failure during a warm reboot. Any ideas?
Thanks,
Daniel
Just spitting in the wind, heating up so that a broken track separates?
That would be unfortunate and almost impossible for someone like me to track down or even repair. The machine also has a quirky LCD backlight; it's not completely dead, it just seems to work when it wants to.
A cold boot doesn't mean that the machine is cold. It's a power switch off -- power switch on procedure as opposed to a three finger salute. If it misbehaves after cold booting when the machine has been running for a while it's got nothing to do with heating up.
Here's a couple of small software cold and warm boot programs to help determine what's really up. One is a cold boot and the other is a warm boot.
You'll need to rename the XXX.txt to XXX.com.
Run them and see what you get.
View attachment COLDBOOT.txt View attachment WARMBOOT.txt
View attachment 58622 View attachment 58623
Code 192 for both. Odd.
Is there a lit LED underneath?
If so, you need to reset that by sliding a switch under there. See the User Guide if you have one.
Underneath the laptop, i.e. on the underside. It's a configuration error indicator that needs resetting if on. Just a vague memory from 760XDs and 600Xs.
