My how quickly things can change.. Yes, we all know that rust never sleeps, but dang..
Last time the hardwares were out of storage, everything ran smoothly. Depending on which machines we're talking about, that would be a lapse of three or maybe five years since. But as it stands, I've got four dead or seriously flagging floppy drives.
Crap. I don't know how to fix floppy drives, not yet, anyway.
First one I found is the Chinon Enhancer 2000 (C-64 etc, accelerated 1541 compatible). It's just all read / write errors galore. It can't even format a disc. This drive was flawless and FAST when last used, and that was 3 yrs ago. What a kick in the teeth.
The next two are the pair of 1/3 height units in an Epson QX-10. First sign of trouble was when both drives refused to eject their media; the little lock bar that pops up to block the disc slot refused to retract when the locking mechanism was released. Once that was sorted, it was clear that neither of the drives could reliably read and/or write to the last tracks on the media. Impossible to dupe a disc, etc.
Finally, to add insult to injury, the lone internal drive in the C-64 Executive flaked out. It gets a few good reads / writes, but soon enough it all goes to crap. There is also a very odd scraping / clicking noise which sounds to be coming from just behind the front bezel. Foreign object, right, but I can't see anything - have to pull it out.
So what the heck do you know about floppy drives? The SX-64 is the imperative, then the Enhancer 2000.
Gah, what a mess.
EDIT: 24-JAN-14 I think I see what's essentially wrong with the SX-64 drive - the head doesn't move, at all, ever. It's not stuck, it can be manually positioned. When the drive is running, it's very difficult to move it at all, so that means the stepper is holding it tight - but it's just not positioning it.
Is that a controller failure?
Found this..
UF2 M54532P TRANSISTOR ARRAY IC (STEPPER DRIVERS)
SUB: MITSUBISHI ULN2064
No stepper action or head assembly barely moves. Check also UF3.
UF3 7404 LOGIC
No stepper action or head assembly barely moves. Check also UF2.
Maybe it is a logic failure. Wow, that would be odd... =/
Gah, what a mess.
Found this..
UF3 7404 LOGIC
