7000 DATA mi>km,1.6093,km>mi,0.6214
7010 DATA yd>m,0.9144,m>yd,1.0936
7020 DATA ft>m,0.3048,m>ft,3.2808
7030 DATA in>mm,25.4,mm>in,0.03937
7040 DATA in>cm,2.54,cm>in,0.3937
7050 DATA in>m,0.0254,m>in,39.37
7060 DATA in2>mm2,645.16,mm2>in2,0.00155
7070 DATA in2>cm2,6.4516,cm2>in2,0.155
7080 DATA ft2>m2,0.0929,m2>ft2,10.764
7090 DATA in3>cm3,16.387,cm3>in3,0.06102
7100 DATA gal>ltr,3.7854,ltr>gal,0.26417
7110 DATA in3>gal,0.004329,gal>in3,231
7120 DATA in3>ltr,0.01639,ltr>in3,61.023
7130 DATA gal>cm3,3785.4,cm3>gal,0.000264
7140 DATA lbs>kgs,0.4536,kgs>lbs,2.2046
7150 DATA mph>ft/s,1.46667,ft/s>mph,0.6818166322
7400 REM only -1s below
7405 DATA f>c,-1,c>f,-1
7490 DATA end..,..
7500 PRINT "Conversion":PAUSE .8:A9$="":B9=0:RESTORE 7000
7510 PRINT Z9$;" conv ";:ACCEPT NULL(Z9$),Z9$
7512 IF Z9$="conv"OR Z9$="conv#"THEN C9=0:GOTO 7800
7518 PRINT C9;"num ";:ACCEPT NULL(C9),C9
7520 READ A9$,B9
7525 IF B9=-1THEN 7900
7530 IF A9$=Z9$THEN 7570
7540 IF A9$="end.."THEN PRINT Z9$;" not found":Z9$="":PAUSE:GOTO 7500
7550 GOTO 7520
7570 ANS=C9*B9
7580 PRINT "ans";C9;A9$;" =";ANS:PAUSE:GOTO 7500
7800 RESTORE 7000
7810 READ A9$,B9$:IF Z9$="conv"THEN PRINT A9$:PAUSE
7815 IF Z9$="conv#"THEN PRINT A9$;" ";B9$:PAUSE
7820 IF A9$="end.."THEN 7500 ELSE 7810
7830 GOTO 7500
7900 IF Z9$="c>f"THEN ANS=(C9*(9/5))+32:A9$=Z9$:GOTO 7580
7910 IF Z9$="f>c"THEN ANS=(C9-32)*(5/9):A9$=Z9$:GOTO 7580
7990 A9$="end..":GOTO 7540
600 PRINT "Wind Chill":PAUSE .6
610 PRINT TEMP;"temp,deg f ";:ACCEPT NULL(TEMP),TEMP
620 PRINT WSPED;"wind speed,mph ";:ACCEPT NULL(WSPED),WSPED
630 WCHIL=35.74+(.6215*TEMP)-(35.75*WSPED^.16)+(.4275*TEMP*WSPED^.16)
640 ANS=WCHIL:PRINT USING"ans wind chill,deg f=###.#";WCHIL:PAUSE:GOTO 600
8000 PRINT "Simpson's Rule":PAUSE 1:Z=0:V=1:Y=0
8005 PRINT "Def.Integral..line 8100":PAUSE 1
8010 PRINT A;"start ";:ACCEPT NULL(A),A
8020 PRINT B;"end ";:ACCEPT NULL(B),B
8030 PRINT C;"step ";:ACCEPT NULL(C),C
8040 D=(B-A)/C:X=A-D
8045 IF (C/2)-INT(C/2)>0 THEN PRINT "..step even #s only":PAUSE :GOTO 8030
8050 X=X+D:IF X>B THEN 8130
8060 IF X=B THEN V=1
8070 IF V=1 THEN 8100
8080 IF V=2 THEN V=4:GOTO 8100
8090 IF V=4 THEN V=2
8100 Y=((-.0944*X^2)+3.4)^2*PI
8105 PRINT "x=";X;" y=";Y
8110 Y=Y*V:IF V=1 THEN V=2
8120 Z=Z+Y:GOTO 8050
8130 F=(Z*D)/3
8140 ANS=F:PRINT "ans=";F:PAUSE:GOTO 8000
Simpson's Rule, 3-2-19
I found this website that calculated the volume of an American football with a definite integral.
https://www.math.ucdavis.edu/~morris/16B/sec5.7.pdf
As I've said before, I'm no programmer and I'm poor at math. But I wanted to see if I could work a definite integral on my TI-74. I found Simpson's Rule which is supposed to work a definite integral. I programmed Simpson's Rule on my 74. I put the definite integral on line 8100. It seems to work okay....at least it gave the results of their football example.
Code:8000 PRINT "Simpson's Rule":PAUSE 1:Z=0:V=1:Y=0 8005 PRINT "Def.Integral..line 8100":PAUSE 1 8010 PRINT A;"start ";:ACCEPT NULL(A),A 8020 PRINT B;"end ";:ACCEPT NULL(B),B 8030 PRINT C;"step ";:ACCEPT NULL(C),C 8040 D=(B-A)/C:X=A-D 8045 IF (C/2)-INT(C/2)>0 THEN PRINT "..step even #s only":PAUSE :GOTO 8030 8050 X=X+D:IF X>B THEN 8130 8060 IF X=B THEN V=1 8070 IF V=1 THEN 8100 8080 IF V=2 THEN V=4:GOTO 8100 8090 IF V=4 THEN V=2 8100 Y=((-.0944*X^2)+3.4)^2*PI 8105 PRINT "x=";X;" y=";Y 8110 Y=Y*V:IF V=1 THEN V=2 8120 Z=Z+Y:GOTO 8050 8130 F=(Z*D)/3 8140 ANS=F:PRINT "ans=";F:PAUSE:GOTO 8000
Football example:
0 start -5.5 [enter]
0 end 5.5 [enter]
0 step 20 [enter]
ans= 232.1679769 in3 - football volume (cubic inches)
(delete line 8105 if you don't want to see X and Y on the display)
1400 DATA met number is the..
1402 DATA metabolic equivalent of task
1405 DATA leisure 5.5 mph = 3.5 met
1410 DATA leisure 9.4 mph = 5.8 met
1420 DATA bicycling general = 7.5 met
1430 DATA mountain general = 8.5 met
1440 DATA fast 14-15.9 mph = 10 met
1450 DATA racing 16-19 mph = 12 met
1490 DATA end
1500 PRINT "Calories Burned Cycling":PAUSE .8:A7$="":RESTORE 1400
1510 PRINT W;"your weight ";:ACCEPT NULL(W),W
1520 PRINT CW$;" (l)bs or (k)gs ";:ACCEPT NULL(CW$),CW$
1530 IF CW$="l"THEN WT=W*0.45359237:GOTO 1560
1540 IF CW$="k"THEN 1560
1550 GOTO 1520
1560 PRINT MT$;" (m)et or (v)iew ";:ACCEPT NULL(MT$),MT$
1570 IF MT$="v"THEN 1600 ELSE 1590
1580 GOTO 1560
1590 PRINT MET;"met ";:ACCEPT NULL(MET),MET:GOTO 1630
1600 READ A7$
1610 IF A7$="end"THEN RESTORE 1400:GOTO 1560
1615 PRINT A7$:PAUSE
1620 GOTO 1600
1630 PRINT MIN;"ride mins ";:ACCEPT NULL(MIN),MIN
1640 ANS=((MET*WT*3.5)/200)*MIN
1650 PRINT USING"ans calories burned ####.#";ANS:PAUSE:GOTO 1500
14000 PRINT "Right Triangle":PAUSE .6:RESTORE 14400:ON ERROR 14490
14005 Z$=D$:PRINT D$;:INPUT " _ _>_ _;_ _ ";D$:IF D$=""THEN D$=Z$
14008 IF D$="h"THEN 14300
14010 IF D$="sa>sb;aa"THEN INPUT "sb ";B,"aa ";C:F=B*TAN(C):GOTO 14210
14020 IF D$="sa>sc;aa"THEN INPUT "sc ";B,"aa ";C:F=B*SIN(C):GOTO 14210
14030 IF D$="sa>sc;ab"THEN INPUT "sc ";B,"ab ";C:F=B*COS(C):GOTO 14210
14040 IF D$="sb>sc;aa"THEN INPUT "sc ";B,"aa ";C:F=B*COS(C):GOTO 14210
14050 IF D$="sb>sa;ab"THEN INPUT "sa ";B,"ab ";C:F=B*TAN(C):GOTO 14210
14060 IF D$="sb>sa;aa"THEN INPUT "sa ";B,"aa ";C:F=B/TAN(C):GOTO 14210
14070 IF D$="sc>sa;aa"THEN INPUT "sa ";B,"aa ";C:F=B/SIN(C):GOTO 14210
14080 IF D$="sc>sb;aa"THEN INPUT "sb ";B,"aa ";C:F=B/COS(C):GOTO 14210
14090 IF D$="sc>sa;ab"THEN INPUT "sa ";B,"ab ";C:F=B/COS(C):GOTO 14210
14100 IF D$="aa>sa;sc"THEN INPUT "sa ";B,"sc ";C:F=ASIN(B/C):GOTO 14210
14110 IF D$="aa>sb;sc"THEN INPUT "sb ";B,"sc ";C:F=ACOS(B/C):GOTO 14210
14120 IF D$="aa>sa;sb"THEN INPUT "sa ";B,"sb ";C:F=ATN(B/C):GOTO 14210
14130 IF D$="ab>sb;sc"THEN INPUT "sb ";B,"sc ";C:F=ASIN(B/C):GOTO 14210
14140 IF D$="ab>sa;sc"THEN INPUT "sa ";B,"sc ";C:F=ACOS(B/C):GOTO 14210
14150 IF D$="ab>sa;sb"THEN INPUT "sa ";C,"sb ";B:F=ATN(B/C):GOTO 14210
14160 IF D$="sa>sb;sc"THEN INPUT "sb ";C,"sc ";B:F=SQR(B^2-C^2):GOTO 14200
14170 IF D$="sb>sa;sc"THEN INPUT "sa ";C,"sc ";B:F=SQR(B^2-C^2):GOTO 14200
14180 IF D$="sc>sa;sb"THEN INPUT "sa ";C,"sb ";B:F=SQR(C^2+B^2):GOTO 14200
14190 PRINT "not found..":PAUSE:GOTO 14005
14200 E=B:B=C:C=E
14210 ANS=F:PRINT "ans";F;SEG$(D$,1,2):PAUSE:PRINT SEG$(D$,4,6);" =";B;";";C
14220 A$=KEY$:IF A$=" "THEN 14210 ELSE 14000
14300 READ H$
14310 IF H$="end"THEN PRINT "end..":PAUSE 1:D$="":GOTO 14000
14320 PRINT H$:PAUSE
14330 GOTO 14300
14400 DATA Right Triangle Sides Angles (deg dec)
14402 DATA make an x y number line
14405 DATA where x y cross the angle is 90 deg
14410 DATA the y axis is Side A (sa)
14415 DATA the x axis is Side B (sb)
14420 DATA the hypotenuse from y to x is Side C (sc)
14425 DATA where y and hypotenuse meet is Angle B (ab)
14430 DATA where x and hypotenuse meet is Angle A (aa)
14435 DATA end
14490 PRINT "error..":PAUSE:GOTO 14000
700 PRINT "Heat Index":PAUSE .6
710 PRINT T;"temp,deg f ";:ACCEPT NULL(T),T
720 PRINT RH;"relative humidity,% ";:ACCEPT NULL(RH),RH
730 A1=-42.379+(2.04901523*T):A2=(10.14333127*RH)
740 A3=(0.22475541*T*RH):A4=(6.83782*10^-3*T^2)
750 A5=(5.481717*10^-2*RH^2):A6=(1.2287*10^-3*T^2*RH)
760 A7=(8.5282*10^-4*T*RH^2):A8=(1.99*10^-6*T^2*RH^2)
770 ANS=A1+A2-A3-A4-A5+A6+A7-A8
780 IF ANS>137 OR ANS<80 THEN PRINT "error..inputs out of range":PAUSE:GOTO 710
790 PRINT USING"ans Heat Index,deg f=####.#";ANS:PAUSE:GOTO 700
900 PRINT "Parabola":PAUSE .6
910 INPUT "radius (x) ";R9,"height (y) ";T9:C9=T9/R9^2
920 Z9=R9^2/(4*T9):PRINT "focus=";Z9:PAUSE
925 INPUT "increment (x) ? ";K9:I9=K9^2*C9:IF K9<=0 THEN 900
930 IF K9>R9 THEN PRINT "max incremented (x)=";R9:PAUSE:GOTO 925
940 PRINT USING"INCREMENT (y)=###.###";I9;:PRINT " @";K9;"(x)":PAUSE:GOTO 925
1100 PRINT "Combined Gas Law":PAUSE .8
1105 PRINT "Enter 0 For":PAUSE .8
1107 PRINT "Desired Quanity":PAUSE .8
1110 PRINT A;"> V1,in3 ";:ACCEPT NULL(A),A:V1=A
1120 PRINT B;"> P1,psi ";:ACCEPT NULL(B),B:P1=B
1130 PRINT C;"> T1,deg f ";:ACCEPT NULL(C),C:T1=C+459.67
1140 PRINT D;"> V2,in3 ";:ACCEPT NULL(D),D:V2=D
1150 PRINT E;"> P2,psi ";:ACCEPT NULL(E),E:P2=E
1160 PRINT F;"> T2,deg f ";:ACCEPT NULL(F),F:T2=F+459.67
1170 IF A=0 THEN X=(V2*P2*T1)/(P1*T2):X$="V1,in3=":A=X:GOTO 1240
1180 IF B=0 THEN X=(V2*P2*T1)/(V1*T2):X$="P1,psi=":B=X:GOTO 1240
1190 IF C=0 THEN X=(V1*P1*T2)/(V2*P2):X=X-459.67:X$="T1,deg f=":C=X:GOTO 1240
1200 IF D=0 THEN X=(V1*P1*T2)/(P2*T1):X$="V2,in3=":D=X:GOTO 1240
1210 IF E=0 THEN X=(V1*P1*T2)/(V2*T1):X$="P2,psi=":E=X:GOTO 1240
1220 IF F=0 THEN X=(V2*P2*T1)/(V1*P1):X=X-459.67:X$="T2,deg f=":F=X:GOTO 1240
1230 PRINT "error..":PAUSE:GOTO 1100
1240 ANS=X:PRINT "ans ";X$;X:PAUSE:GOTO 1100
1 DATA 27,99
2 DATA 32,152
3 DATA 23,81
4 DATA 25,98
5 DATA 31,151
6 DATA 28,112
499 DATA 1.E+126,1.E+126
500 ON ERROR 810:RESTORE:X=0:Y=0:N=0:SUMX=0:SUMY=0
503 MEANX=0:MEANY=0:SUMX2=0:SUMY2=0:SUMXY=0
505 N=N+1:READ X,Y:PRINT "Stat";X;Y
510 IF X=1.E+126 AND Y=1.E+126 THEN 580
520 SUMX=X+SUMX:SUMY=Y+SUMY
530 MEANX=SUMX/N:MEANY=SUMY/N
540 SUMX2=SUMX2+X^2:SUMY2=SUMY2+Y^2
550 SUMXY=SUMXY+(X*Y)
570 GOTO 505
580 PRINT :PRINT "sumx =";SUMX:PAUSE
590 PRINT "sumy =";SUMY:PAUSE
600 PRINT "meanx =";MEANX:PAUSE
610 PRINT "meany =";MEANY:PAUSE
620 PRINT "sumx2 =";SUMX2:PAUSE
630 PRINT "sumy2 =";SUMY2:PAUSE
640 PRINT "sumxy =";SUMXY:PAUSE
650 A=(SUMX*(((SUMX*SUMY)/(N-1))-SUMXY))/(((N-1)*SUMX2)-SUMX^2)+(SUMY/(N-1))
660 PRINT "A intercept =";A:PAUSE
670 B=(((N-1)*SUMXY)-(SUMX*SUMY))/(((N-1)*SUMX2)-SUMX^2)
680 PRINT "B slope =";B:PAUSE
690 SX=((((N-1)*SUMX2)-SUMX^2)/((N-1)*((N-1)-1))):SX=SQR(ABS(SX))
700 SY=((((N-1)*SUMY2)-SUMY^2)/((N-1)*((N-1)-1))):SY=SQR(ABS(SY)):R=(B*SX)/SY
710 PRINT "R cor coef =";R:PAUSE
720 PRINT "SX =";SX:PAUSE
730 PRINT "SY =";SY:PAUSE
740 PRINT "N =";N-1:N=N-1:PAUSE
770 INPUT "est x or y ";Z$:IF Z$="x"THEN 790
780 IF Z$="y"THEN 800 ELSE 500
790 INPUT "est,x enter y ";Y:X=(Y-A)/B:PRINT "est x =";X:PAUSE:GOTO 770
800 INPUT "est,y enter x ";X:Y=A+(B*X):PRINT "est y =";Y:PAUSE:GOTO 770
810 PRINT "Error..redo":PAUSE:END
1 DATA Ohm DC..use + - keys
2 DATA E=12:R=2:I=E/R:PRINT I
3 DATA I=SQR(P/R)
4 DATA I=P/E
5 DATA R=E/I
6 DATA R=P/I^2
7 DATA R=E^2/P
8 DATA E=I*R
9 DATA E=P/I
99 DATA end..
100 C9=0:DIM A9$(105)
110 C9=C9+1:READ A9$(C9)
120 IF A9$(C9)="end.."THEN 200
130 GOTO 110
200 C9=0
210 C9=C9+1:PRINT A9$(C9):IF A9$(C9)="end.."THEN 230
220 IF KEY$="+"THEN C9=C9+1:PRINT A9$(C9)
225 IF C9>98 THEN C9=99
230 IF KEY$="-"THEN C9=C9-1:PRINT A9$(C9):IF C9<2 THEN C9=0 ELSE 230
240 IF A9$(C9)="end.."THEN C9=C9-1:GOTO 230
250 GOTO 210
6000 PRINT "Vectors":PAUSE .6:DEG
6002 PRINT "..all angles deg dec":PAUSE 1.2
6005 VA=0:VB=0:PRINT X;"# of vectors ";:ACCEPT NULL(V),V
6006 IF V=0 THEN V=X ELSE X=V
6008 IF V>9 OR V<2 THEN PRINT "error..2 to 9":PAUSE:GOTO 6005
6010 PRINT M9(V);"#";V;"mag ";:ACCEPT NULL(M9(V)),M9(V)
6012 PRINT N9(V);"#";V;"dd ";:ACCEPT NULL(N9(V)),N9(V)
6015 IF N9(V)<0 THEN N9(V)=N9(V)+360
6020 IF V=1 THEN 6100 ELSE V=V-1:GOTO 6010
6100 V=X:PRINT"..."
6110 A=SIN(N9(V)):SA(V)=M9(V)*A:A=COS(N9(V)):SB(V)=M9(V)*A
6120 VA=VA+SA(V):VB=VB+SB(V):V=V-1:IF V=0 THEN 6200
6130 GOTO 6110
6200 F=ATN(VA/VB):E=VB/COS(F):E=ABS(E)
6210 IF VA>0 AND VB<0 THEN F=180+F
6220 IF VA<0 AND VB<0 THEN F=180+F
6230 IF VA<0 AND VB>0 THEN F=360+F
6235 RESMAG=E:RESANG=F
6240 PRINT "resmag= ";E;"mag":PAUSE:PRINT "resang= ";F;"dd":PAUSE
6250 PRINT "resang-360= ";RESANG-360;:PRINT "dd":PAUSE
6260 PRINT "[spc] or [enter]":IF KEY$=" "THEN 6240 ELSE 6005
6500 PRINT "PR-RP":PAUSE .6:DEG
6510 C=0:D=0:Z$="?"
6520 PRINT "1)";C;": ";:ACCEPT NULL(C),C
6530 PRINT "2)";D;": ";:ACCEPT NULL(D),D
6540 PRINT Z$;" : pr rp ";:ACCEPT NULL(Z$),Z$
6550 IF Z$="0"THEN END
6560 IF Z$="pr"THEN Y=C*SIN(D):X=C*COS(D):GOTO 6600
6570 IF Z$="rp"THEN R=SQR(C^2+D^2):A=ASIN(D/R):GOTO 6610
6580 PRINT "error..":PAUSE:GOTO 6540
6600 PRINT "x=";X;"y=";Y:PAUSE:GOTO 6520
6610 IF C<0 AND D>0 THEN A=ABS(180-A)
6620 IF C<0 AND D<0 THEN A=ABS(180-A)-360
6630 PRINT "r=";R;" ";CHR$(242);"a=";A:PAUSE:GOTO 6520
1 DATA one
2 DATA two
3 DATA 3
98 DATA end..
100 PRINT "MEMORY":PAUSE 1
110 P=0
120 READ M$
130 INPUT "Remember ? ";T$
140 IF T$="?"THEN PRINT "Ok. ";M$:PAUSE:P=P-1:GOTO 130
150 IF T$=M$THEN PRINT "Got it.";M$:PAUSE:P=P+1:GOTO 170
160 IF T$<>M$THEN PRINT "Nope.":PAUSE:P=P-1:GOTO 130
170 PRINT M$;" : Points ";P:PAUSE
180 IF M$="end.."THEN PRINT "Restarting..":PAUSE 1:RESTORE:GOTO 110
190 GOTO 120
