TI-99/4A Expansion Questions
Hello everyone,
I have 2 questions:
1) I know I can install two RS-232 cards in the expansion box for a total of 4 serial (using Y-splitters) and 2 parallel ports but can I install more than one 32KB card for 64KB or more memory?
2) Does anyone have a P-CODE card that they would like to sell...I've been looking for over a year and have not had any luck?
Thanks,
Scott
"The 32k can not be duplicated in multiple cards/expansions so if you want to use another device that provides 32k you must remove or disable the existing 32k device."
A more active place for questions:
I have a P-Code card with an undiagnosed fault (might be bad GROM, might be something else) I could send to a new home if someone were interested in An Project.
Hey Bear, I would take a chance and never mind having a new project. I'll PM you...Thanks
I have a new issue...When I try to format a 40 Track SS-SD Floppy disk, it takes about 10 minutes, goes up to about 340 on the counter, and then gives me a "Disk Error 41".
Anyone seen this issue before? Any help would be appreciated.
Thanks
