TMC card on IBM 5155
wulp
Antwerp, Belgium
Hello,
I have an IBM 5155 with is a TMC card. It has 2 serial ports, 1 parallel port, 256k and an RTC.
I can't find any information about that (e.g. how to set up the RTC).
Does anyone has information about that?
Thanks!
It is possible that a photo of decent resolution will enable someone to properly identify the card. Consider putting such a photo on an image hosting website, then posting a link to that image. Identification may then lead to additional information.
Does the card have an FCC ID printed on it somewhere? If so, what is it?
One of the clock utilities at [here] may work.
Of those, I think that you should first try David_M's clock software.
The data on the card:
FCC IO: FHG5UA-MFP
The 'FHG' portion is a code ('grantee code') for the maker, and the '5UA-MFP' portion is the maker's reference (sometimes reflecting the part number).
A grantee code search of FHG at [here] informs me that the maker is Taiwan Mycomp Corporation.
Unfortunately, that does not help.
